FeatureMerger broken when using a 2015.1 workspace on a 2015.0 server
  • May 21, 2015
  • 49 views
We've recently upgraded to Desktop 2015.1 but we are still using Server 2015.0. We've come across an error when using FeatureMerger. We've made no changes to it so it is still using Version 12 of the transformer but if we upload a workbench using 2015.1 then we get the error. We think it could be that we just need to upgrade to Server 2015.1 too but wanted to check here first because we haven't got a dev environment to upgrade to, we only have a live environment.
The error is as follows:
2015-05-21 11:18:20| 0.2| 0.0|ERROR |FeatureMerger(ReferenceFactory): The clause 'ATTR_CONFLICT_RES REQUESTOR_IF_CONFLICT IGNORE_NULLS No' within 'FACTORY_DEF * ReferenceFactory FACTORY_NAME FeatureMerger INPUT REFERENCER FEATURE_TYPE CSV_CSV_1 INPUT REFERENCEE FEATURE_TYPE BulkAttributeRenamer_OUTPUT REFERENCE_INFO ATTRIBUTES REFERENCE_TABLE @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>col3<closeparen>,FeatureMerger) @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>23_col3<closeparen>,FeatureMerger) AUTO ATTR_ACCUM_MODE HANDLE_CONFLICT ATTR_CONFLICT_RES REQUESTOR_IF_CONFLICT IGNORE_NULLS No MERGE_ATTRIBUTES Yes MANAGE_FME_TYPE Yes MODE COMPLETE PROCESS_DUPLICATE_REFERENCEES No REFERENCEES_FIRST No OUTPUT COMPLETE FEATURE_TYPE FeatureMerger_MERGED' is incorrect. The clause must look like: ATTR_CONFLICT_RES <newAttr>
Thanks,
Peter.
  • May 21, 2015
Hi
the general rule is to never upload a workspace saved with a newer version of FME Desktop, it's bound to lead to problems at some point.
I suspect your problems will go away if you revert to FME Desktop 2015.0 or you upgrade to FME Server 2015.1
David
Thanks David, we upgraded FME Server and it is now working fine.
  • January 6, 2016
thanks that solved our problem too
