featuredata set
  • June 25, 2013
  • 27 views
The reader gets its dtat from a featureclasswich is a part of a featuredataset named "Topology"
The writer creates a new featureclass a personalgeodatabase.
But the writer puts the featureclass automatically in a featuredataset neamed "Topology".
When you look at the parameters of the featureclaass you see: Feature Dataset:<not set>.
I would like to make a featureclass with out a feature dataset. I can't find the solution.
Is there someone who can help me.
Thank you very much.
Best answer by fmelizard
If you are not using dynamic translation, or referencing the writer schema via a template, then you should let safe know abou it.
Itay
fmelizard
Forum|alt.badge.img+22
  • June 25, 2013
Itay
