Feature Merger merges wrong data when Requester/Supplier is a number
  • February 27, 2017
  • 84 views
clemensb
Forum|alt.badge.img+5
i’m calculating the sum of some areas and afterwards I add the calculated value to the original attributes. The values of the field GSTNR, on which the area calculation is grouped on, are 68226.3 and 68226.30 created in an AttributeManager of the Fields KG_NR and GST_NR, they are not numbers.
Somehow the Feature Merger merges the attribute values of 68226.3 to 68226.30.
Interestingly in the Data Inspector the value of 68226.3 is 68226.300000000003, in the output FGDB is the correct value.
But when I add any character to GSTNR in the AttributeManager(“text”+ KG_NR and GST_NR) e.g. text68226.3 the Feature Merger delivers the right result. So i tried with a StringFormatter to tell FME it’s a string, than again I get a wrong result.
The Data is stored in a FileGDB.
Is this a bug or am i doing something wrong? I added a zip with the workspace and some sample data.
Thanks for your help!
Workspace:
  • February 27, 2017
Try setting the FeatureMerger comparison mode to "String" rather than Automatic.
  • February 28, 2017
Agree. Try setting String to the Comparison Mode.
It's a bit strange that the concatenation result from "68226" (string) and ".3" (string) will be treated as a numeric value (64 bit real) internally, though the result from "68226" and ".30" is treated as a string value, with FME 2016.1.3.
In FME 2017.0 build 17254, "68226" and ".3" became a string too. An improvement has been done here?
clemensb
  • February 28, 2017
Thank you, this works
