Feature Merge Type to NONE on FeatureMerger
  • Jan 13, 2017 8:30 AM UTC
  • 8 replies
  • 55 views
jpvo
In many occasions I use a FeatureMerger to verify the match of ID between two datasets.
In this situation I really don't want to merge attributes at all. I use the Feature Merge Type "geometry" but then I need to restor the original geometry of the requestor (GeometryExtractor / Replacer).
My life would be much easier with an option "None" which checks the match between two dataset but leave untouched both requestor and suppliers so I don't have to worry about attribute accumulation.
  • Jan 13, 2017 9:09 AM UTC
Hi JP, I agree that would be helpful. Maybe post it as an idea?
I'm sure you've thought about this too, but I often use the Referenced output port for this scenario, rather than the Merged port. That way the output features remain untouched.
jpvo
  • Jan 13, 2017 10:08 AM UTC
Hi David,
My mistake, I was thinking I had posted it as an idea. using the Referenced is usefull but less logic, less "readable" and therefore less maintainable over time.
Forum|alt.badge.img+54
  • Jan 16, 2017 2:51 PM UTC
You can use an InlineQuerier in place of a featuremerger to do this which would remove the need to rebuild any geometry
e.g. SELECT req.* FROM Requestor req, Supplier sup WHERE req.name = sup.name
erik_jan
Forum|alt.badge.img+26
  • Jan 16, 2017 2:53 PM UTC
Hi David,
You have posted it as an idea and I voted for it days ago.
itay
Forum|alt.badge.img+19
  • Jan 16, 2017 3:09 PM UTC
Optionally that is if you are using database formats, the joiner\\SQLexecutor can also be used.
jpvo
  • Jan 17, 2017 8:41 AM UTC
How would you the "NotMerged" features when using a SQLExecutor?
I use something like this but I don't really like it: Merge Result and Initiator based on ID.
Is there a "select" I could use to return the initiator in the result port if the query has no results?
jpvo
  • Jan 17, 2017 8:57 AM UTC
I should use more InlineQerier but there is an overhead as you have to manually make the query for Unreferenced and NotMerged Ports:
demo-inlinequerier.fmw
itay
  • Jan 17, 2017 9:18 AM UTC
You could use the except oprator, if your format supports it, but I have to admit that its not a very nice solution, I would use the Joiner since it will always return a _matched_records attribute and it can be optimized.
