Feature Class extraction
  • February 5, 2013
  • 71 views
Does anybody know how to extract information from one feature class and output as a new Feature Class ?
(I am pulling from an SQL database for GeoMedia to place into a GeoMedia access database)
Example: I have a Water network (feature class) with two attributes with the following options
Status: conceptual, proposed, in service
and
Owner: City, Other
I want to extract all the IN SERVICE pipes that are of type CITY.  Does anybody know the write transformer that would produce these results?
mark2atsafe
Forum|alt.badge.img+59
  • February 5, 2013
Hi
There are two ways to do this:
1) When adding the GeoMedia SQL Server reader, click on the parameters button and set a where clause (eg where status="IN SERVICE" and owner="CITY")
2) Don't set a where clause but use the Tester or TestFilter transformer to carry out this.
#1 is better because it means you are reading less data into your workspace. #2 means you are reading everything first and then filtering it.
Hope this helps
Regards
Mark
Mark Ireland
Product Evangelist, Safe Software Inc.
sam-tizz
  • February 9, 2013
The best option is to filter  records in the where clause itself as Mark suggested, else
You can also use attributefilter based on status first and then owner type
sam
