Fatal Error: "READERR"
  • January 9, 2015
  • 23 views
I have been getting this Fatal Error when reaching the dissolver transformer in my process. The dissolve process appears to be working, and eventually gets hung up and after a few more minutes I get a pop up message box that says "[READERR} Read Error".  The actual process never completes so I don't have a finished log file with a description of this error,  I haven't seen any posts about this error, so any insight would be much appreciated.
Best answer by jonathan
If this is replicatable, the best thing to do is probably to send a bug report with the source dataset(s) plus the workbench to safes support (support@safe.com), so they can investigate and hopefully fix it.
  • January 14, 2015
