Extrude edges, surface
  • May 22, 2020 1:44 PM UTC
  • 180 views
kidega
Forum|alt.badge.img+9
Hello,
Is there a good approach to extrude only outer edges from top image? Images below extrudes all faces (internal as well) but am only interested in extruding (external faces). Basically thinking of top image as a building roof, altough it's a terrain and extruding to "walls". On the lowest image I used PlanarityFilter to try filter faces at bottom but doesn't feel like a good approach.
Thanks.
  • May 22, 2020 3:37 PM UTC
Hi @kidega, hopefully the BRepSolidBoundaryCreator.Beta custom transformer from FME Hub could be a solution. This transformer creates side-wall and bottom surfaces for an input surface.
Example
kidega
  • May 24, 2020 10:48 AM UTC
Hi @takashi,
Thanks for your suggestion of using the custom transformer BRepSolidBoundaryCreator.Beta. I tried it on some basic surfaces and it works fine. Depending on the source surface it sometimes doesn't seem to go all way. I tried to continue on filtering from original extrusion of the terrain model and got some results. The workflow also takes help of custom transformer SurfaceNormalExtractor from the Hub to filter on surface normals, https://hub.safe.com/publishers/safe-lab/transformers/surfacenormalextractor
For some reason I had to expose the attributes for surface normals in the custom transformer for the Output but then it seem to work. Not sure if I missed something there.
Sharing the workflow. It probably could be optimized.
kidega
  • Dec 10, 2023 8:47 PM UTC
Updated workflow which will extract terrain elevation faces downwards and optimize polygons using NeighborhoodAggregator and MeshSimplifier.
