Extract (only) summation stats from FME log files ?
  • May 11, 2017 7:54 AM UTC
  • 22 replies
  • 206 views
lifalin2016
Forum|alt.badge.img+42
I have some FME workspaces, that investigate the recent FME log files from previous translations. This is done to uncover any problems in a rational way.
I want to extract the statistics at the bottom, but the "|STATS |" string is used extensively thru-out the log file, and would completely swamp the output if this was the only search criteria (while reading as a TEXT file).
Do anyone have a good idea how to extract just the summation details ?
Cheers
Lars I
Best answer by takashi
Hi @lifalin2016, interesting challenge. This workflow extracts the text block of consecutive STATS lines in the bottom of a log file.
itay
Forum|alt.badge.img+19
  • May 11, 2017 8:08 AM UTC
I would look into searching for the log lines that contain Features Read Summary & Features Written Summary since they are always present.
  • May 11, 2017 8:16 AM UTC
All the statistics are available in the shutdown script, it's really easy to e.g. write a part of it to a custom log file: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Configuration/FME_END_PYTHON.htm
Also lots of good info here:
https://knowledge.safe.com/articles/849/how-to-extract-and-use-log-information-in-workbenc.html
lifalin2016
  • May 11, 2017 1:28 PM UTC
David_r: Well, I'm investigating multiple log files from other workspace translations, as a separate workspace translation, so a shutdown script in any of these previously run workspaces isn't really an option. And I don't want to be dependent on some logic in these workspaces anyhow.
itay: I've looked at the "Feature Read Summary" and "Feature Written Summary" lines, but I'm really just interested in the numbers below these lines, and how can I get them without all the irrelevant STATS lines in the rest of the log file ?
  • May 11, 2017 2:14 PM UTC
itay
  • May 11, 2017 2:21 PM UTC
I have done in the past something similar to what @takashi proposes, that is one way to do it....
f.kemminje
Forum|alt.badge.img+11
  • May 12, 2017 6:44 AM UTC
Write a python program and loop thru each log file , go to last line of log file and search for string "stats" and print it or write to another text file.
  • May 12, 2017 9:38 AM UTC
Python script version inspired by @fkemminje's post.
# PythonCaller Script Example
# Extracts consecutive STATS lines in the bottom of a log file.
# Assume that the character encoding of the log file is UTF-8.
import os, codecs
class LogSummaryExtractor(object):
    def input(self, feature):
        path = feature.getAttribute('_logFile') # FME log file path
        if path and os.path.exists(path):
            with codecs.open(path, mode='r', encoding='utf-8') as f:
                stats = []
                for row in f.readlines()[-1::-1]:
                    if '|STATS' in row:
                        stats.append(row)
                    elif stats:
                        break
                feature.setAttribute('_summary', ''.join(stats[-1::-1]))
        self.pyoutput(feature)
itay
  • May 12, 2017 10:29 AM UTC
No need to over complicate things with exotic scripting :), it can all be done with FME...
ftwritten.fmwt
lifalin2016
  • Jun 9, 2017 1:34 PM UTC
Hi itay,
Most of the comments here have been helpful, but your solution is the one that taught me a few new tricks. And it works too :-) I do get the last batch of "STATS" lines that I wanted.
Using a variable to track reading state, and reading the log files backwards, are tricks I'll keep in mind for future use.
I did write a small Python transformer also, but knowing how to do it without coding is more versatile.
Cheers
Lars I.
gio
Forum|alt.badge.img+15
  • Jun 9, 2017 3:18 PM UTC
same way you extract data from any structured text file..
basically regexp searching, which is made easier nowadays due to the vastly improved stringsearcher.
an variablesetter/retriever combination.
I don't use a separate creator for the variablesetter, that's not necessary.
It' is for instance a handy to process your log after runtime to check for warnings and which attributes are involved in the warning etc. Then auto generate a report.
For some good reading in the morning with coffee....;)
asadamjad
Participant
Forum|alt.badge.img+12
  • Participant
  • Oct 27, 2022 12:54 PM UTC
ftwritten.fmwt
what is the text line number
asadamjad
Participant
  • Participant
  • Oct 27, 2022 12:56 PM UTC
\\CreateGemWPL.log' does not exist
f.kemminje
  • Oct 28, 2022 6:38 AM UTC
@asadamjad​ instead you select your own log file. Any fme log file work here.
f.kemminje
  • Oct 28, 2022 6:47 AM UTC
import os, codecs
                stats = []
                    if '|STATS' in row:
                        stats.append(row)
                    elif stats:
                        break
f.kemminje
  • Oct 28, 2022 6:49 AM UTC
ftwritten.fmwt
👍 Good!
asadamjad
Participant
  • Participant
  • Oct 28, 2022 10:30 AM UTC
its not working
f.kemminje
  • Oct 28, 2022 5:43 PM UTC
here is the fme workbench
asadamjad
Participant
  • Participant
  • Oct 28, 2022 6:54 PM UTC
I m getting this
asadamjad
Participant
  • Participant
  • Oct 28, 2022 7:00 PM UTC
is there anyway to get summry like this s
f.kemminje
  • Oct 29, 2022 12:20 PM UTC
open python caller
replace feature.getAttribute('_logfile') from the left hand panel
just double click on "_logfile"
fme will copy attribute from left window.
This is the issue with python caller transformer 2022, when we send the fme to other system feature.getAttribute function not doing its job. we need to double click on attribute and re define the variable.
@mark2atsafe​
asadamjad
Participant
  • Participant
  • Oct 29, 2022 12:23 PM UTC
I didnt get it
asadamjad
Participant
  • Participant
  • Oct 29, 2022 12:26 PM UTC
I attached the WS please check
