esri Roads & Highways
  • March 9, 2017
  • 50 views
runneals
Forum|alt.badge.img+31
I'm looking for (and didn't seem to find) any transformers for working with esri's Roads & Highways. I figured someone out there in the community might have some tips/experience working with it to specifically use as a look-up (send in XY & get location on the network).
Thanks in advance.
  • March 9, 2017
If I'm not too mistaken, isn't R&H; using linear referencing?
If so, take a look at the transformers under the Linear Referencing category of the Transformer Gallery, notably the Measure*-family of transformers and the Snipper.
runneals
  • March 9, 2017
It does use LRS. I think we're going to end up developing some custom transformers to do snap to closest lrs segment, then get location descriptor attributes.
  • March 9, 2017
Thanks for confirming. Sounds like a great idea to invest in a good set of custom transformers, this is typically something that gets reused a lot throughout an organization.
