[Error] Transforming data/time format of data through converter but failing due to error regarding plugin changing locales.
  • Oct 18, 2022 10:10 AM UTC
  • 52 views
I am attempting to convert the date format of an Esri layer file and am met with "The loaded plugin's FMEPluginCapabilities 'LogCount_func' has changed the process locale to 'English_United Kingdom.1252' which is incompatible with FME 'English_United Kingdom.utf8' locale. Please see 'pluginbuilder/cpp/fmeplugincapabilities.h' documentation"
https://www.safe.com/support
kailinatsafe
Forum|alt.badge.img+24
Hello @pgf11​, thanks for posting! Sorry you're encountering this. If you wouldn't mind providing a little more information on the following topics, that would be great!
  • What version and build of FME Workbench are you using?
  • What formats are you connecting to in this workspace? Are you trying to read or write from an SDE Geodatabase (aka using the GEODATABASE_SDE) format?
  • If you are utilizing the GEODATABASE_SDE format, what is the type of underlying database? And what is the version of the SDE geodatabase?
  • What Esri application do you have installed on your machine, please include the version as well.
Happy to help, Kailin
