Edit Vertex Z value in polygon
  • Feb 7, 2014 5:04 AM UTC
  • 116 views
venu
Forum|alt.badge.img+5
I would like to change z value in a polygon for particular vertex is there any way in FME.
I have more than 1000 polygon.
3rd and 4th vertex z values are need to change.
Please guide me
Thanks in advance
Best answer by takashi
A possible way I can think of is:
1) Transform a polygon into individual vertices (Chopper).
2) Add sequential number to the vertices (Counter: use polygon ID as Counter Name).
3) Determine if vertex is 3rt or 4th one (Tester), and change z value of  them (3DForcer).
4) Connect all vertices to re-create the original polygon (PointConnector: use polygon ID as Connection Break Attributes).
If you need to restore original attributes, consider using the FeatureMerger after.
Takashi
  • Feb 7, 2014 5:48 AM UTC
Takashi
venu
  • Feb 7, 2014 10:12 AM UTC
Thanks, works fine
