DWG writter coordinate system error
  • Oct 23, 2023 9:21 AM UTC
  • 202 views
hi, i am getting errors, when trying to implement an old workspace, witch was created in datainteroperability extension in arcmap 10.8. Now upgrading to a higher version of python and ArcGISPro i have difficulties with dwg writter.
As soon as i add layers from .shp, to dwg writzter i get an error. .shp has correct coordinate system. Also an old model on older version works. Does someone have an idea what could it be?
There is a log of an error:
FME Configuration: Destination coordinate system set to input coordinate system `_FME_0'
Dynamically creating layer `visina_topo_znak'
Dynamically creating layer `id_visine'
ACAD writer: Splitting bulk features into individual features
FME Configuration: Using ESRI Reprojection Engine
Reprojector: Implicit reprojection prohibited from `_FME_1' (GCS: `GCS_Slovenia_1996') to `_FME_0' (GCS: `GCS_unnamed') using the Esri reprojection engine; specify a geotransformation using @Reproject or the EsriReprojector transformer
Esri Reprojector: No valid geotransformation from GCS 'GCS_Slovenia_1996' to GCS 'GCS_unnamed' available
Storing feature(s) to FME feature store file `C:\\Users\\mrobar\\AppData\\Local\\Temp\\ArcGISProTemp16844\\fmetool-1698042275094_16844_log.ffs'
Feature Type: `DKN00'
Attribute(32 bit integer)     : `Id' has value `0'
Attribute(string: UTF-8)      : `autocad_linetype_scale' has value `50'
Attribute(string: UTF-8)      : `autocad_lineweight' has value `-3'
Attribute(string: UTF-8)      : `fme_basename' has value `Območje_zakoličbe'
Attribute(string: UTF-8)      : `fme_color' has value `1,0,1'
Attribute(string: UTF-8)      : `fme_dataset' has value `\\\\kotel\\Tehnika_Distribucija_Upravljanje\\Geodetske storitve\\Zakoličbe trase obstoječega omrežja\\Ptuj\\11 - Orešje Ptuj ( Cestno podjetje Ptuj)\\data in\\Območje_zakoličbe.shp'
Attribute(string: UTF-8)      : `fme_feature_type' has value `Območje_zakoličbe'
Attribute(string: UTF-8)      : `fme_geometry' has value `fme_polygon'
Attribute(entangled: string: UTF-8): `fme_type' has value `fme_area'
     entangled to shapefile_type
Attribute(32 bit integer)     : `multi_reader_full_id' has value `2'
Attribute(32 bit integer)     : `multi_reader_id' has value `2'
Attribute(string: UTF-8)      : `multi_reader_keyword' has value `SHAPEFILE_1'
Attribute(string: UTF-8)      : `multi_reader_type' has value `SHAPEFILE'
Attribute(string: UTF-8)      : `multi_writer_id' has value `3'
Attribute(string: UTF-8)      : `shapefile_type' has value `shapefile_polygon'
Coordinate System: `_FME_1'
Geometry Type: IFMEPolygon
Name(UTF-8): `shapefile'
Boundary:
  Geometry Type: IFMELine
  Number of Coordinates: 31 -- Coordinate Dimension: 2
  (565207.7898532329,143995.26519034058)(565201.0318669025,143984.0009605419)(565192.3284050822,143988.5705238562)(565196.773413972,143994.76178624295)(565176.2946230127,144010.79556830414)
  (565170.8820630051,144004.6528861355)(565165.1821007878,144010.31931735575)(565169.4683593595,144015.24057719857)(565154.545829514,144027.4643516466)(565150.8580294922,144024.91880966164)
  ...Skipping coordinates...
  (565102.1911549075,144066.43535780162)(565097.3163400572,144069.6125609409)(565102.316975058,144075.4069475308)(565106.7619839478,144080.4075825326)
  (565123.3513921257,144065.96130364016)(565133.610876617,144055.061240267)(565165.6583517408,144028.41685355268)(565187.8040210316,144011.1924440991)(565194.2768582329,144005.1314251367)
Coordinate system conversion during translation is not possible
AutoCAD Writer: Abort() called. Aborting writing
Feature output statistics for `ACAD' writer using keyword `ACAD_3':
                Features Written
id_visine                                  20
visina                                   20
visina_topo_znak                              20
Total Features Written                           60
Translation FAILED with 33 error(s) and 18 warning(s) (360 feature(s) output)
Stored 1 feature(s) to FME feature store file `C:\\Users\\mrobar\\AppData\\Local\\Temp\\ArcGISProTemp16844\\fmetool-1698042275094_16844_log.ffs'
FME Session Duration: 1 minute 1.3 seconds. (CPU: 37.5s user, 17.2s system)
END - ProcessID: 4968, peak process memory usage: 715556 kB, current process memory usage: 336192 kB
Program Terminating
Translation FAILED.
During translation, some features were read that did not match a reader feature type in the workspace. This can happen if the reader dataset is changed, or a reader feature type removed or renamed.
nielsgerrits
Forum|alt.badge.img+67
What coordinate system is defined in the writer? Because that is what the error is about.
It looks like the writer had a crs specified that is unknow to the new version of FME?
  • Oct 23, 2023 10:22 AM UTC
My database MYSQL is in EPSG 3794 and also shapefile. When i write to dwg from sql database log is ok. as soon as i add shapefile i get an error. it looks like, that transformer is trying to reproject something, but there is no need.
