DWG filecopy, units being changed from metric to imperial
  • Nov 7, 2019 3:01 PM UTC
  • 89 views
bjudes
Forum|alt.badge.img+10
I am trying to copy a selection of dwg's from one folder to another. I am using the filecopy writer to achieve this. I am having a problem however, with the original dwg's the units are set to metric, but when I copy them to the new destination using filecopy they switch to imperial. I can't see any settings to change this, would anyone know how to keep these as metric?
Thanks
B
edit. I have uploaded the workspace also. Thanks for the help..
sigtill
Forum|alt.badge.img+25
  • Nov 7, 2019 4:05 PM UTC
Do you have any additional files with different endings in the same folder (ie *.prj etc)? Try to copy those also.
bjudes
  • Nov 7, 2019 4:10 PM UTC
Yes I have prj, but I was copying these as well already. Seems strange as I am not actually reading the dwg into the dataset.
