Duplicating Points When Converting CAD to GIS?
  • August 19, 2013
  • 0 replies
  • 26 views
When I run a typical read and write from CAD to GIS with the box checked "attribute schema" it duplicates/doubles my blocks/points. If I run it with the group entities "Layer Name"  it is fine? Any ideas on what can cause this? Thank you in advance for any help. I am using ArcGIS D.I.
