Draw line between point on sat image
  • May 3, 2020 3:01 PM UTC
  • 49 views
boubcher
Forum|alt.badge.img+11
Hello there
we need to generate a report for then many roads,
we need to draw a line between each point and show the distance value
The same as the image below
is there a way we could use FME in this case
danilo_fme
Forum|alt.badge.img+58
  • May 3, 2020 4:15 PM UTC
Hi @boubcher
In your case I suggest you the transformer MapnikRasterizer.
There is a insteresting information on this MapnikRasterizer. With this transformer you can associate vector on Image.
Question: Is there id order from the points that you want connect?
Thanks in Advance,
Danilo
