Download link without the Html page
  • Jan 17, 2017 11:46 AM UTC
  • 8 replies
  • 58 views
boubcher
Forum|alt.badge.img+11
you are integrating the download service in our app , could we we get back from the server only the URL download , without the HTML page
Best answer by larry
And if you do a call to the fmedatadownload service (http://fmeserver/fmedatadownload/<repository>/<workspace>) with the following options, the returned json contains the download url.
http://fmeserver/fmedatadownload/<repository>/<workspace>?<parameters>&opt;_showresult=false&opt;_servicemode=sync&opt;_responseformat=json
{"serviceResponse": {
   "statusInfo": {
      "mode": "sync",
      "status": "success"
   "jobID": 25449,
   "url": "http://fmeserver/fmedatadownload/results/FME_7116131F_1484685939433_768.zip"
itay
Forum|alt.badge.img+19
  • Jan 17, 2017 12:19 PM UTC
Using the FME Server data download produces a url that can be found via the API, is that what you are referring to?
  • Jan 17, 2017 2:05 PM UTC
boubcher
  • Jan 17, 2017 4:28 PM UTC
@itay
Yes that link , hiw could we get it
itay
  • Jan 17, 2017 7:58 PM UTC
@itay
Unfortunately I was wrong and the url cannot be found via the API (unless I missed something) however the FME_SERVER_DEST_DIR paramaeter can help since the last part will contain the name of the zip file produced by the datadownload service and that way you can reconstruct the download url.
Hope this helps
  • Jan 17, 2017 8:27 PM UTC
If you workspace notifies a topic on success, you can build the download link from the notification information and store it somewhere.
DATADOWNLOAD_ASYNC_JOB_SUCCESS arrived at 15:20:36
    "ws_topic": "DATADOWNLOAD_ASYNC_JOB_SUCCESS",
    "id": "25446",
    "NumFeaturesOutput": "2",
    "OutputLocation": "C:\\ProgramData\\Safe Software\\FME Server\\DefaultResults\\FME_7116131F_1484684423129_4544.zip",
    "StatusMessage": "Translation Successful",
    "subscriber_folder": "C:\\ProgramData\\Safe Software\\FME Server\\DefaultResults\\FME_7116131F_1484684423129_4544_nw",
    "ResultRootDir": "/fmedatadownload/results",
    "LogFileName": "job_25446.log",
    "timeFinished": "Tue-17-Jan-2017 03:20:23 PM",
    "logHome": "C:/ProgramData/Safe Software/FME Server///Logs",
    "timeRequested": "Tue-17-Jan-2017 03:20:23 PM",
    "StatusNumber": "0",
    "requestKeyword": "FILE_DOWNLOAD_SERVICE",
    "jobsuccess_topic": "DATADOWNLOAD_ASYNC_JOB_SUCCESS",
    "jobfailure_topic": "DATADOWNLOAD_ASYNC_JOB_FAILURE",
    "timeStarted": "Tue-17-Jan-2017 03:20:23 PM"
The OutputLocation have the zip file name, the ResultRootDir have the url path.
You then concatenate <Your FME Server URL>ResultRootDir/<filename> and this link will get you the file.
Example with above notification:
http://fmeserver/fmedatadownload/results/FME_7116131F_1484684423129_4544.zip
  • Jan 17, 2017 9:07 PM UTC
   "statusInfo": {
      "mode": "sync",
      "status": "success"
   "jobID": 25449,
itay
  • Jan 18, 2017 5:23 AM UTC
   "statusInfo": {
      "mode": "sync",
      "status": "success"
   "jobID": 25449,
Nice one @larry, missed it somehow on the API info page...
boubcher
  • Jan 18, 2017 6:30 AM UTC
@larry thanks thats exactley what we are looking for
