Download FME build 16177
I need to download the build 16177 64bit windows version of FME. I can however not find it on the "Past FME Downloads" page (https://www.safe.com/support/support-resources/fme-downloads/archived/). Where would I be able to find the install file for this?
PS: The reason I need this specific version is because the client is using this build for his FME Server and I need to modify their models.
  • August 17, 2017
I suspect build 16178 won't be a problem, according to the change log almost nothing changed between them: https://downloads.safe.com/fme/2016/whatsnew_2016.0.1.2.txt
As a side note, you can use the 32-bit version of FME Desktop even though FME Server is 64-bit, it makes not difference whatsoever.
Otherwise you'll have to contact Safe support.
Thank you for this answer. I will continue working with b16178. Hopefully this will not create issues..
