donuts on the edges, clipping one polygon from other on the edge
  • Feb 20, 2018 3:27 PM UTC
  • 72 views
Hello,
Let's say that I have one big polygon A and two smaller polygons B and C.
One small polygon B is fully inside the big polygon A and the other one C is on the border of polygon A.
I need to clip them B and C from the big polygon A.
I use donutBuilder and for one small polygon which is fully inside, I get a good result (big polygon A with a hole B).
The other polygon C which intersects the border of big polygon A is clipped from the big polygon but the part which was outside the big polygon remains as an object. How to get clean cut on the border?
  • Feb 20, 2018 3:32 PM UTC
Hi @kbachmatiuk, consider using the Clipper instead of the DonutBuilder. Send B, C to the Clipper port, send A to the Clippee port, and take the resulting feature output via the Outside port.
So smart you are ;) Thank you a lot, it helped.
