Does anyone have an easy set of instructions I can follow for mosaicking
  • August 7, 2013
  • 54 views
Hi
I've given this a try on 5 occasions.
No luck so far.
Most of the time the files want to take over an hour to load into FME.
If anyone has an easy set of instructions I can follow, it would be greatly appreciated.
fmelizard
Forum|alt.badge.img+22
  • August 7, 2013
Can you specify some more about the input you have?
  • August 7, 2013
Hi
I have a 3 or 4 mosaics I need to create.
1 have 10 aerial images.
5 at 30cm
5 at 10cm
30 aerials at 50cm
8 satellite tiles
fmelizard
  • August 7, 2013
The amount and type of raster in your case should not be an issue, I would look into the temp directory and possibly here too.
Hope this helps
