Distance calcul between a lot of points by the road
  • Feb 26, 2020 6:42 PM UTC
  • 63 views
I would like calculate the distance between points by the road.
I have 1 file with origin points ( 1 000 000 points) and 1 file with destination points (10 000).
I would like the distance between every origin - destination points, so 1 000 000 x 10 000 distances.
I try to do, with only 12 origins points and 5 destinations points :
But the problem is for the FromTo, it take only one destination on a camp common with the origin points.
How i can to do to have 12 x 5 = 60 combinaisons ?
Thanks a lot,
Matthieu
Hi @tanmat, I came across a post that contained solutions to a similar question you had: Connect all From points to all To points in FromToBuilder. A little addition is to set a common attribute for both your origin and destination points with an AttributeCreator, and use this common attribute as the join attribute in the FromToBuilder. Hope this helps!
  • Feb 28, 2020 9:10 PM UTC
Hi, thanks for your response. It's work. ;o)
I go to try with all the points soon.
