dissolver failure
  • February 18, 2015
  • 7 replies
  • 117 views
jaro
Hi there,
Anyone has an idea what may be wrong? I suspect that I reached some limit with the dissolver function. In easy cases it just works OK. But when I do dissolving of a 2500 polygons into one, it just forgets to create the donuts inside.
This is my input:
This is what I expect:
and this is what I actually get:
Any help is highly appreciated. Thank you in anticipation,
Jaroslav
jaro
  • February 18, 2015
Update: the problem is not related to the number of polygons but to the bad guy which is the big donut-circle around.
  • February 19, 2015
Hi Jaroslav,
I was not able to reproduce similar situation to yours anyhow. Unavoidable computational error sometimes may cause such an exceptional result, but the exact reason is unclear.
I would recommend you to contact Safe support and send the data and workspace which reproduce the situation.
Takashi
jaro
  • February 21, 2015
Just for case, if anyone is interested:
I applied the tiler to the donut circle splitting it into about 10 pieces and dissolved it with other polygons this way and it worked.
jaro
  • February 21, 2015
Conclusion: the dissolver does not work with the geometry type "FME donut". The detailed analysis showed I was trying to dissolve a lot of "FME polygons" with a "FME donut" which lead to incorrect results. Once I applied the DonutBridgeBuilder, it was converted to "FME polygon" and dissolved as it should.
  • February 22, 2015
This may also be the "ellipse vs. ellipse" issue. (https://drive.google.com/file/d/0B0ufVP2t0eApMVZkT1J2dkRoRDA/view?usp=sharing)
jaro
  • February 24, 2015
Thanks Takashi. It might be some computational error, but I am OK with the workaround by now.
  • April 28, 2017
thank you Jaroslav,
using the DonutBridgeBuilder to convert the "FME donut" geometries also fixed my problem with the Dissolver!
