Display results as Columns instead of row
  • June 22, 2015
  • 40 views
ruby
Is it possible to have my results display as Asset Name Headers instead of row.
I would like the results to display as following:
Date, Air Switches, Power Transformers, Voltage Regulators, PCB
06-2015, 1            ,   3                         , 3                          ,2
Current results
  • June 23, 2015
I suppose that you have created the count values with the ListElementCounters. If my understanding is correct, this might help you.
(1) Set the asset name to the "Element Count Attribute" parameter for each ListElementCounter. i.e. "Air Switches", "Power Transformers", "Voltage Regulators", "PCB".
(2) Send the features to an Aggregator (Keep Input Attributes: Yes).
Takashi
ruby
  • June 23, 2015
Takashi,
How can I get rid off the Asset Name in Column A.  I don't need that since it tell me what the asset is on the top.
Thank you
  • June 23, 2015
Consider using the AttributeRemover to remove the unnecessary attribute.
ruby
  • June 23, 2015
It worked.  Thank you so much Takashi :)
