display previous month date
  • Jul 22, 2015 3:32 PM UTC
  • 5 replies
  • 107 views
ruby
Currently my reader read's results in July for June and I have time stamper to disply the date, it displays July date, is there anyway I can have a transformer that will display June date for June results but i always run the workbench in current month for previous month.
Thank you
  • Jul 23, 2015 10:08 PM UTC
I'm unclear your requirement. If you run the workspace at July 31, for example, what date string should be created?
Takashi
pratap
Forum|alt.badge.img+12
  • Jul 24, 2015 6:06 AM UTC
Create an attribute for date with constant value in attribute creator instad of using time stamper.
ruby
  • Aug 3, 2015 2:18 PM UTC
Takashi, I am running a data that is June and I run the FME on July 1, So when I run it displays results as with July date because I have TimeStamper, but I would like it to display June.
Pratap, I am bit confused with how attribute creator can give me previous month date.  Since I am very new to FME , I am still learning.
Thank you
  • Aug 3, 2015 3:45 PM UTC
Does this help you?
See also this article.
Formating Dates Using the DateFormatter Transformer (https://knowledge.safe.com/articles/Samples_and_Demos/Formating-dates-using-the-DATEFORMATTER-transformer)
ruby
  • Aug 3, 2015 4:08 PM UTC
Takashi, It worked.  Thank you so much for all your help!
