DGNstyler - multiple cell names
  • February 19, 2014
  • 5 replies
  • 68 views
Is it possible to set the Cell Name for multiple cells in the DGN Styler?
Running 2012 SP2 Build 12238 Win64
fmelizard
Forum|alt.badge.img+22
  • February 20, 2014
I think that you will need to use multiple DGNStylers for that.
fmelizard
  • February 20, 2014
Actually the DGNStyler makes use of the igds_cell_name format attribute, if you map the cell names to this attribute, it should be possible.
  • February 20, 2014
Itay,
My cell library consist of about 30 cells.  Setting up 30 DGNstylers is an option but not one I would prefer.Can you explain what you mean by "map the cell names to this attribute"?  I have exposed the igds_cell_name but can't work out how to ask the Styler to find this value.  It only has Select Cell Name, Link to Parameter or Clear Cell Value  as options. I have set Cell Mode  to Library.
A correction to my original query- I'm using 2013 SP4 build13547 win 64 for this script.
Thanks,
fmelizard
  • February 21, 2014
Hi Russ,
By simply creating the following attributes igds_cell_name = name as in library and igds_type = igds_cell, you dont need to use the DGNStyler, you do however need to point to the cell(s) library file(s) at the writer (see Navigator>Writer>Parameters>Cell Library File).
You can use an AttributeValueMapper for the names and an AttributeCreator for the type or both if you have an attribute on which to use the conditional values.
See  also http://fmepedia.safe.com/articles/FAQ/Microstation-Design-Cells-and-FME.
  • February 24, 2014
That did the trick, thanks,
Russell
