Detecting a specefic type of lines
  • Apr 17, 2018 2:28 PM UTC
  • 107 views
lianaolianov
Forum|alt.badge.img+5
Hello,
Is there a way in FME to detect lines having the beginning or the end vertice like shown in following images.
Thank you
erik_jan
Forum|alt.badge.img+26
  • Apr 17, 2018 2:32 PM UTC
Seems like what you are looking for is vertices with a very sharp angle.
You can find these using the SpikeRemover transformer.
It will let you define the maximum angle in the sharp corner.
The Changed output port will get you all these lines.
You might want to store the original geometry (GeometryExtractor) and restore it after the SpikeRemover (using GeometryReplacer).
Hope this helps.
lianaolianov
  • Apr 17, 2018 2:37 PM UTC
Hope this helps.
I tried the spike remover but failed to put the correct parameters
I gor all features on the rejected port
  • Apr 17, 2018 2:41 PM UTC
If you could post a couple of offending features here in an FFS file, perhaps someone could come up with some working parameters.
lianaolianov
  • Apr 17, 2018 2:43 PM UTC
I found the right combinaison of parameters to detect them
Thank you very much
