Dear colleagues! I've read this article https://community.safe.com/s/article/writing-citygml-example and I have 1 goofy question. How could I change repeat times of my texture, and it will correlate with the length of the wall?
  • Jan 21, 2021 11:54 AM UTC
  • 58 views
naste4kina
chrisatsafe
Hi @naste4kina​ ,
Good question - you've found the correct right parameter to get this done. By default, these values are set to 1.0 and 1.0 which will apply the appearance once to the entire geometry. If you want the appearance to repeat, you can adjust this value to the number of times you want it to repeat.
As specified in the doc, the parameters do the following:
  • Texture u Repeat Factor can be used to specify the number of times the texture is repeated in rows.
  • Texture v Repeat Factor can be used to specify the number of times the texture is repeated in columns.
Here's an example of what a 5u/5v repeat looks like vs a 1u/5v repeat. This does apply to the entire height/width.
2021-01-21_9-34-50
naste4kina
  • Feb 3, 2021 7:39 AM UTC
Hi @chrisatsafe​ ,
thank you so much for your clarifications!! everything is clear
chrisatsafe
Hi @chrisatsafe​ ,
Great, thanks for letting me know you got it all working!
