Date
  • Jun 19, 2017 11:39 AM UTC
  • 8 replies
  • 77 views
nath
Forum|alt.badge.img+7
I have a field type string contains a date like "20170104" and i have to change it to "2017/01/04".
I have tried de dateformatter (then the model crashes), the stringsearcher (i don't find the right expression) or the attributesplitter but i have no delitimer .
Has somebody a quick way to do this?
  • Jun 19, 2017 12:02 PM UTC
Hi @nath, the DateFormatter with these parameters should work.
  • Source Date Format: Unknown - Automatic Detection (or %Y%m%d)
  • Destination Date Format: %Y/%m/%d
Would your Workbnch still crash with the parameters above?
gio
Forum|alt.badge.img+15
  • Jun 19, 2017 12:05 PM UTC
@nath
The dateformatter works fine for your requirement.
source: %Y%m%d
dest format:
%Y/%m/%d
gio
  • Jun 19, 2017 12:07 PM UTC
maybe you are including the quotes? Don't.
Does it crash on the dateformatter at all? Or maybe later in process?
nath
  • Jun 19, 2017 12:12 PM UTC
I got the crash when i tried using the DateFormatter. I thought that it had something to do because i had merged the tables from shp and csv files together. It worked fine on the shp but not with the csv.
Forum|alt.badge.img+54
  • Jun 19, 2017 12:13 PM UTC
It's not the approach I'd use here, but if you want to split a string without a delimiter you can use a format string to split an attribute, e.g.
4s2s2s
would split 20170104 into
2017
01
04
  • Jun 19, 2017 12:21 PM UTC
Theoretically the DateFormatter should work fine regardless of the source data format. If the workspace always crashes in your specific condition, I would recommend you to contact safe to clarify the cause.
In the interim, the StringReplacer would also be a workaround.
  • Mode: Replace Regular Expression
  • Text To Replace: ^(....)(..)(..)$
  • Replacement Text: \\1/\\2/\\3
  • Jun 19, 2017 12:27 PM UTC
If running 2016 depending on the build there is a bug that means automatic detection does not work
nath
  • Jun 19, 2017 12:35 PM UTC
Thanks everyone. If I do it with a small amount of data, it works well, so I think it has something to do with an earlier problem that always crashes my workspace. I've contacted Safe and they are looking for a solution.
