DatasmithWriter - PNG Issue
  • Apr 1, 2022 6:17 AM UTC
  • 55 views
gisplan
Hello everyone.
I know there might be not too many using the DatasmithWriter (since I didn't find any question about it here yet). But I hope maybe someone can help or has an idea.
I'm using the DatasmithWriter and got a surface that has a raster placed with the AppearanceSetter. This Raster has an Alpha Value (it's a branch, so everything around is meant to be transparent).
When I write the DatasmithFile it tells me Raster could not be written (nothing more).
When I remove Alpha Band it works, with Alpha it doesn't.
I read Details about Datasmith, it says 32Bit, Alpha8, Int8.
This is all the case for my Raster so im running out of ideas what might be the problem.
PNG_Issue
Thank you in advance for any hints.
kailinatsafe
Forum|alt.badge.img+24
Hello @gisplan​ , would you mind sharing what version/build of FME Desktop you're using? I think there was a bug that sounds similar with the Datasmith Writer (FMEENGINE-72341) that has been resolved in newer builds, which you can find on our downloads page. You should be able to find the fix in FME 2022.0 Beta b22317+
Please let me know if that doesn't resolve your issue! Best, Kailin.
gisplan
  • Apr 8, 2022 11:39 AM UTC
Hi Kailin
Thank you for your answer!
My built is: Build 21784 - WIN64.
Now i chose to work with simplified trees made with polygons only and give them a color.
But im sure in future this question is coming back and i will try it with the recent FME version.
Regards
