Data Inspector will not open
  • Nov 7, 2014 5:51 PM UTC
  • 121 views
I have been outputting to FME Data Inspector quite intensively over the last 2 days and now it has stopped opening even though the workbench is running successfully.
I have tried the solutions mentioned in this post:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000cnQMAAY
Ie: I have purged inside FME and deleted all I could out of the FME temp folder on the C drive.
When I change the options to output to FME Universal Viewer, this works.  So it must be some sort of memory issue with FME Data Inspector??
fmelizard
Forum|alt.badge.img+22
  • Nov 8, 2014 2:47 PM UTC
Sometimes the DI process is still running in the background, you can check that with the tasks manager. If its running kill the process.
  • Nov 10, 2014 10:26 AM UTC
Thanks Itay, that was it :)
  • Nov 12, 2014 1:23 PM UTC
We realize that for a lot of Windows users the Data Inspector no longer pops to the front when you send it data from Workbench which is a bit annoying.  The issue seems to be related to a Windows update and unfortunately we may not be able to go back the old behaviour.  Our team is still trying our best to find a way to solve this.
  • Nov 14, 2014 9:49 AM UTC
Thanks for the update Ken.
Since I killed the process in Task Manager, Data Inspector has been opening again normally from my Workbench (on Windows 7).  So for the time being everything is working ok.
