Data Inspector is not filtering records correctly when using wild card (%) and having ~300000 records with ~70 attributes
  • March 2, 2021
  • 0 replies
  • 30 views
zuzanna_sz
Forum|alt.badge.img+4
I noticed some strange behavior - when inspecting the data with the wild card to view all records with any value per attribute (in the Visual Preview or in the separate Inspector window) when there are couple of hundreds of records and tens of attributes (71 in this particular case) the tool is mixing the selected attribute and displays count of filtered records for the second one to the right (like in the picture below: I filter for all records with ObjSyleVoc value, and it is giving me the number of ObjUsageContextVoc. It also displays the updated table view for ObjUsageContextVoc, not the selected in the filter bracket. )
Any ideas why it is happening? It works for smaller tables...
Screenshot 2021-03-02 164716
