Cylindrical to Conic reprojection of Global rasters
  • Jun 19, 2020 8:44 PM UTC
  • 36 views
I'm trying to reproject rasters from WGS84.PlateCarree to LambertAzimuthalEqualAreaSouthPole using a Reprojector Transformer,they have varying extent/ Resolution and Spacing.
It often fails, my suspicion is that it has a lot to do with the extents of the input raster, particular when those extents are approaching linear unit values that represent the dateline and 90 / -90 latitude receptively . Sometimes the transformer runs successfully but just produces a very narrow vertical strip other times it fails and leaves translation log outputs like this
(You can see the extents of the input raster here i was using).
Are there any set rules that i should be following to guarantee success?
I can give more details and examples if necessary.
Many thanks
David
Forum|alt.badge.img+63
Not a definitive answer, but something you may want to try is clipping the input raster to be a little bit smaller (although that may leave you with a little bit of a gap after reprojecting). Alternatively, as this is a south pole projection, cut out everything north of the equator.
