Creating Polygons from lines
  • May 20, 2023 7:20 PM UTC
  • 137 views
jurgenmack
Forum|alt.badge.img+9
I have a workbench that creates points from coordinates then generates lines. I am only getting three sides of the polygon and I have not found a transformer that will close the forth side.
Can you suggest a solution?
DanAtSafe
Forum|alt.badge.img+23
  • May 20, 2023 9:57 PM UTC
Hi @jurgenmack​ Use the LineCloser - it adds the start point to the end, closing the line with an additional line segment.
jurgenmack
  • May 20, 2023 10:09 PM UTC
Thanks Dave
I was searching for something like polygon closer or finisher.
