Creating a field and inserting financial date (dependent on date value)
  • June 24, 2013
  • 5 replies
  • 106 views
Hi guys,
I am new to FME and wondered if there was a way to fill a field, by querying the date field, and inserting the relevant financial year.
In SQL you would use something like SELECT * FROM tblCustomers WHERE date >= '01/04/2012' AND date<= '31/03/2013'
Please advise?
Thanks,
Gary
fmelizard
Forum|alt.badge.img+22
  • June 24, 2013
Have a look at the attribute creator, you can design your tests in it.
  • June 24, 2013
So Itay,
You would create an attribute i.e. the financial year field and then conditionally assign a text string based on a few conditions, for example:
1. Use the conditions above to filter the data
2. Assign a text value when the conditions are true
3. Add the text value to a new field
Could you describe the process to me in via AttributeCreator.
Sorry, I really am a novice.
Cheers,
Gary
fmelizard
  • June 24, 2013
Hi Gary,
The following Evangelist  article describes in details the use of this new functionality, I hope it is enough to get you started!
Cheers,
Itay
Forum|alt.badge.img+53
  • June 24, 2013
Worth noting that the functionality described in the evangelist article is only available if you have updated to SP1
  • June 25, 2013
Hi Itay,
Thanks very much! Second model built and these methods are really handy to have in an FME users' toolkit.
Have a good day!
Cheers,
Gary
