create a personalised ID with letter and number
  • Oct 18, 2017 3:13 PM UTC
  • 7 replies
  • 102 views
alc33
Forum|alt.badge.img+14
Hello,
I would like to create a personalised ID (counter personalised) with letters and number.
I use 2 letters (A to Z) and 1 number (1 to 9), so I would like something like that :
AA1
AA2
AA3
AB1
AB2
AB3
I don't know how to do that and I don't find the solution on the web. Maybe a python script? But I haven't no knowledge on this langage.
If you have any idea...
Thank you for your future answer.
Best answer by ebygomm
And an fme solution, ignoring zeros
  • Oct 18, 2017 3:56 PM UTC
Here's a quick and dirty solution using a Python script:
import fmeobjects
class AlphanumericCounter(object):
    def __init__(self):
        self.counter = 0
    def counter_as_str(self):
        a = self.counter // (26*9)
        b = (self.counter - (a*26*9)) // 9
        c = self.counter - (a*26*9) - (b*9)
        return chr(65+a) + chr(65+b) + str(c+1)
    def input(self,feature):
        feature.setAttribute('id', self.counter_as_str())
        self.counter += 1
        if self.counter > (26*26*9):
            raise fmeobjects.FMEException('Too many features!')
        self.pyoutput(feature)
Each output feature will have a new attribute "id" that contains the counter.
If the number of features exceeds 6084 (id > ZZ9), it will terminate the translation with an error message. PythonCaller parameters:
Forum|alt.badge.img+54
  • Oct 18, 2017 5:20 PM UTC
  • Oct 19, 2017 1:49 AM UTC
The NumToAlphaConverter from FME Hub could also be used here.
  • Oct 19, 2017 1:57 AM UTC
import fmeobjects
    def __init__(self):
        self.counter = 0
        self.counter += 1
Close! The range of number should be 1 to 9 ;-)
  • Oct 19, 2017 7:14 AM UTC
Ah, yes... But everyone knows that an array starts at 0, not 1 ;-)
  • Oct 19, 2017 7:28 AM UTC
But thanks for the tip, I've fixed the code above
alc33
  • Oct 19, 2017 8:02 AM UTC
Hello,
Thank for all yours replies and for your reactivity!
I choose to evacuate the 0 for a specific reason, that's why I ask only 1 to 9 ;) thanks david_r for the adaptation of your code :)
Have a good day everyone!
