Create a center line from two original lines and resample all three to have matching (perpendicular) vertices
  • Mar 1, 2023 10:09 PM UTC
  • 6 replies
  • 191 views
james_c_452
Forum|alt.badge.img+10
I'm wondering if something is possible at all in FME.
I have two parallel 3D lines on a railroad. A "left" line and a "right' line.
I want to create a new line at the center of these two lines (the railroad center)
Once this is done I would like to resample all three lines together so that they all have vertexes that are perpendicular to the center line.
This is exactly what the Topodot tool "center line extraction" does if you adjust element vertices. I was wondering if it is possible to do in FME so I can automate it. I don't have any python skills to make something
The result would look like this
Any advice would be appreciated
Thanks
daveatsafe
Forum|alt.badge.img+24
  • Mar 2, 2023 9:54 PM UTC
Hi @james_c_452​,
This looks like an interesting exercise. Would you be able to share some samples of these railway lines for testing?
james_c_452
  • Mar 2, 2023 10:24 PM UTC
Hi @james_c_452​,
Hi @daveatsafe​ ,
Here is a small sample of some rail lines before I used the other tool I was talking about. Which makes a centerline, and can adjust the vertices to 1m so they are aligned with each other like the picture above
daveatsafe
  • Mar 3, 2023 9:52 PM UTC
Hi @daveatsafe​ ,
Hi @james_c_452​,
The distance between the rails is fixed and the curves are smooth, so the OffsetCurveGenerator may do a good job. You will need to separate the left and right rails, then use only one side to the generate the appropriate offset for the centerline.
james_c_452
  • Mar 5, 2023 2:57 AM UTC
Hi @daveatsafe​ ,
I don't think that tool will work in this case. In the past I have used it and it created a 2D line. What I'm after is a new center line in 3D midway between the left and right rails. The left and right rails don't have a consistent distance apart. There is some different how they have laid track and there are differences in height around corners
Thanks
markvv
  • Mar 5, 2023 7:09 PM UTC
Hi @james_c_452​
This one is indeed interesting. I do not think it's perfect, but I came up with the following method. I have attached the workbench.
Be aware that the Z values are interpolated and that the resampled vertices don't always have the 1 meter interval, especially at the end of the line.Screenshot 2023-03-05 195531
james_c_452
  • Mar 7, 2023 5:00 AM UTC
Hi @james_c_452​
Hi @markvv​ ,
That's pretty good thanks! Seems to work pretty well. I worked out how to remove the weird ends of lines (Join a vertex to the next vertex, calculate line lengths, remove anything not between 0.99-1.01, then make the lines).
However there is a random problem in the middle of another file I tested. It seems the left/right/centre attribute has got all muddled leading to some funny results. Do you know why this is doing this? I haven't found where in your workspace is causing this
