Count number of points on polygon
  • May 4, 2016
  • 48 views
ingalla
Forum|alt.badge.img+10
I have dissolved a large number of polygons into larger chunks, and now need to count the number of points that are over each of the chunks. I am having a bit of a mental block on how to count the points and write them to the polygon record so that I can perform a calculation on it.
As can be seen below the three polygons in green contain, starting from the left, 3, 24 and 2 points.
All suggestions welcome
pratap
Forum|alt.badge.img+12
  • May 4, 2016
Have you tried PointOnAreaOverlayer?
Pratap
