Could not open File Geodatabase table `Delta_Block_Polygon'
  • Sep 18, 2017 3:23 PM UTC
  • 96 views
I keep getting an error trying to write to a specific table, getting an ESRI gdb error message (http://support.esri.com/en/technical-article/000004275).
It claims that the table name has a leading underscore.
I placed a StringReplacer (Image 1)
I keep getting the same error listed in the ESRI blog above????
Geodatabase Error (-2147467259): General function failure.
Any suggestions appreciated
Best answer by clives_online
Seems the problem is poor ESRI documentation!!!
I searched ESRI Reserved words at http://support.esri.com/en/technical-article/000010906
A number of key Reserved words like SDE and DELTA are missing!!
fmelizard
Forum|alt.badge.img+22
  • Sep 18, 2017 3:37 PM UTC
Hi @clives_online, are you writing to an existing table or creating a new one? If existing, is it open in any other applications? Are you able to share the workspace?
  • Sep 19, 2017 8:46 AM UTC
fmelizard
  • Sep 19, 2017 3:07 PM UTC
Hi @clives_online, without the use of those reserved words are you able to write?
