Could not connect to FME Core. Please ensure that it is running.
  • Feb 22, 2018 4:18 PM UTC
  • 66 views
Tried all the "solutions" in the provided link, and changing my port. It was working 1 days prior to the errors
fmelizard
Forum|alt.badge.img+22
  • Feb 22, 2018 9:03 PM UTC
Hi @mcdimad
  • Can you please share your install type with us (Express, distributed etc) and FME Server version
  • If distributed can you share the kind of setup you have?
  • Are all of the services running? Do any fail to start?
  • Make sure all of the Server components are running with the correct permissions
  • You might want to double check that the user running the FME Server Engine has the correct security permissions on the System Share.
  • Do you see any errors in the FME Server logs which might give us more of a clue?
