Copying Elevation to Measure
  • Aug 6, 2024 8:52 PM UTC
  • 55 views
matthewb
Forum|alt.badge.img+12
I have a very large dataset where all of the polylines have elevation that should be measure data.  The custom transformer ElevationtoMeasureCopier is such a memory hog that the workbench is failing on my computer and on my server.  Is there a different way to copy the elevation data to measures?
itsmatt
Forum|alt.badge.img+48
  • Aug 7, 2024 8:44 AM UTC
three things to try:
  1.  Make sure feature caching is off
  2. upgrade the transformers inside of the CustomTransformer to the latets version. This may give you a bit of help.
  3. Consider running the database in batches. You could develop a process to run the whole thing in chunks, e.g., 100,000 features at a time. There are parameters in the readers which can let you control the number of features to read and from which feature to start at.
    https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/reader_parameters_featuresToRead.htm
    Using a workspace runner you could configure the main workspace to run 10 times or so each on a different 100,000 features. This assumes 1,000,000 features.
