Copy macros in fmf file
  • Oct 22, 2015 3:21 PM UTC
  • 44 views
Hi everybody,
I am trying to copy a MACRO into another MACRO within a fmf file.
Maybe its the best to show you guys the code of the fmf file:
 DEFAULT_MACRO VAR1 "something" DEFAULT_MARCO VAR2 "anything" // ... some (uninteresting) code ... DEFAULT_VALUE VAR1 "$(VAR1)" DEFAULT_VALUE VAR2 "$(VAR2)" // ... some (uninteresting) code ... INCLUDE \ [		\ 	set logger [open c:/log.txt w+];	\ 	puts "MACRO VAR2 VAR1";	\ 	puts $logger $(VAR1);\ 	puts $logger $(VAR2);\	 ]
So, I want to copy the content of VAR1 into VAR2 (important line: puts "MACRO ...";). The expected result of log.txt is therefore:
 something something
 However, it is always
 something anything
 I tried many varieties for this code, experimented with the syntax and so on.
But nothing works so far.
How can I copy the values?
Thank you very much
ben
geosander
Forum|alt.badge.img+7
  • Nov 19, 2015 4:27 PM UTC
I'm no expert in this field, but I do notice a typo in the example above. It says "DEFAULT_MARCO VAR2". But that probably doesn't help you...
  • Nov 23, 2015 1:54 PM UTC
thank you for your answer! You are right, unfortunately that is not the problem ;-) However, I solved this by implementing the copy procedure within my reader directly and not within the fmf file.
geosander
  • Nov 23, 2015 2:27 PM UTC
That probably is a safer way, yes :)
Good to hear that it's solved!
