Copy datamodel of File Geodatabase to a new File Geodatabase
  • Feb 7, 2022 2:32 PM UTC
  • 46 views
I want to do some transformation on a schema/datamodel of a GDB and write it into a new GDB (which should be basically the same schema with these adaptions). But i do not get any output if i use Format: schema (any) and feature reader. Does anyone has some ideas for me? I´m a newbee using FME.
  • Feb 7, 2022 2:34 PM UTC
