Coordinate system British National Grid Long/Lat (OSGB 36) [EPSG: 4277] to British National Grid (OSGB 36) [EPSG: 27700]
  • Jul 30, 2018 10:07 AM UTC
  • 6 replies
  • 340 views
Hello All,
British National Grid Long/Lat (OSGB 36) [EPSG: 4277] seems to be missing from FME's suite of coordinate systems - or am I mistaken?
I have a table with Longitude and Latitude data in this projection and I want to create points from them, and then convert them to British National Grid (Meters) (OSGB 36) [EPSG: 27700]. I can try to use the Reprojector transformer, but I can't see EPSG: 4277 anywhere.
Is there anything which I could use instead? Or is there another solution such as creating a custom coordinate system?
Many thanks,
Jane
Best answer by ian_vertigis
OSGB36 LL and National Grid seem to have been added to FME 2023.
Forum|alt.badge.img+54
  • Jul 30, 2018 10:35 AM UTC
Do you have ArcGIS installed on the same machine? If you do, you can use the EsriReprojector transformer
  • Jul 30, 2018 10:52 AM UTC
Many thanks for this - no, I don't, but I have QGIS (though I have only dabbled with it) which may have similar? My problem is, though, that while I can transform the data in MapInfo, I would really like to be able to create a workspace in FME (as I have several tables) so I can run the process repeatedly.
Many thanks,
Jane
  • Jul 30, 2018 11:07 AM UTC
Many thanks,
Jane
The EsriReprojector is a transformer within FME that uses the Esri libraries, not much help for you though.
You should be able to create a custom coordinate system. This link may help
https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw?
  • Jul 30, 2018 11:14 AM UTC
Many thanks for your reply, that looks very useful.
ian_vertigis
Forum|alt.badge.img+20
  • Jul 4, 2023 9:44 AM UTC
  • Jul 4, 2023 9:57 AM UTC
Thank you, that will be really useful when we get the new version.
