Converting large numbers
  • Nov 15, 2022 6:44 AM UTC
  • 108 views
rmpayaby
Forum|alt.badge.img+3
Hello,
I have an Excel-file where one of the attributes contains large numbers such as 3.0230003003349996e+19.
I want these numbers to be in a format without the e-notation such as 30230003003349996. What's the fastest way to do this?
itsmatt
Forum|alt.badge.img+48
  • Nov 15, 2022 7:50 AM UTC
Hmmm, you mean the actual number 30230003003349996000? Or you just mean to chop of the "e+n" as it if were a string?
If you just want to keep the number and keep it in excel you can set a custom format in the output like here:
If you are finding you're losing precision you might need to convert the numbers to a string
  • Nov 15, 2022 8:57 AM UTC
You can use a StringFormatter with something like this:
imageFor "num" = 3.0230003003349996e+19 it returns 30230003003349995520
