Convert from WGS84 to GDA94
  • May 21, 2018 5:36 PM UTC
  • 116 views
Hello everyone,
I have two software that accept geometry in two different format. Software A uses WGS84 and B uses GDA94. I need to translate geo data on the fly between two system (e.g. A SQL trigger exists that updates record in other system's database table when data is updated and vice versa).
I want to know how can I convert geo data from one format to other using *within SQL*. I cannot use FME Desktop and FME API since that would require solution to work outside SQL Server.
Any help is appreciated, thanks in advance.
Regards,
Bhargav
stalknecht
Forum|alt.badge.img+22
  • May 23, 2018 9:05 PM UTC
When the trigger is fired you can use xp_cmdshell to start an fme.exe process to do the conversion.
  • May 24, 2018 2:39 PM UTC
Hi @stalknecht, thanks for the response.  This is good alternative.  However, is there a chance to call CLR function from within SQL server? Something along the lines of below (not actual code)
SELECT FmeTransformFactory.Convert(WSG84_Geometry_Column, GDA94) as 'GDA94_Converted_Geometry'
I hope it makes sense.
Regards,
Bhargav
stalknecht
  • May 24, 2018 8:17 PM UTC
Regards,
Bhargav
Nope, it's not available.
