Convert 22770 (metric) to Lat/Long
  • Jun 7, 2023 3:50 PM UTC
  • 90 views
Greetings,
I have tried several formulae, but no convert metric to DD??
Any suggestions appreciated.
@Value(_inside_x)(@CoordSys(EPSG:4326))
@Value(_inside_x(@CoordSys(EPSG:4326))
Thanks
Clive
daveatsafe
Forum|alt.badge.img+24
  • Jun 7, 2023 5:01 PM UTC
Hi @Clive Swan​,
You can use the AttributeReprojector transformer to convert your attribute values from EPSG:22770 to EPSG:4227, which will give you the lat/long coordinates in the same datum.
Hi @Clive Swan​,
Hi Dave,
Thanks for the suggestion.
I want to keep the Easting/Northing and add Lat/Long from the _x,_y​ coordinates.
Thanks
Clive​
daveatsafe
  • Jun 7, 2023 10:36 PM UTC
Hi Dave,
Thanks
Clive​
Use an AttributeCopier to copy _inside_x to Longitude and _inside_y to Latitude, then use the AttributeReprojector on Longitude and Latitude
