conversion to cityGML
  • September 4, 2013
  • 77 views
Hi !
I want to conversion some files( such as 3ds, dae or skp files) to cityGML files. Help me please!    There is a tutorial the web site
http://fmepedia.safe.com/articles/FAQ/Explanation-of-the-CityGML-format. But it does not update. For instance the document for fme safe 2012 but I use fme safe 2013 or fme beta 2014. And some transformers are not similar between two versions.
  • September 5, 2013
Since FME keeps compatibility with previous versions, I think the documentation basically can be applied to the work with newer FME.
Just be aware that some transformer names have been changed.
e.g. old --> current
Concatenator --> StringConcatenator
AppearanceAdder --> AppearanceSetter
If you type an old name on the canvas window, FME shows it as an alias for the current name, so you can select the correct transformer.
Takashi
  • September 5, 2013
Thanks.
I tried to  apply the documentation that 3D workshop but it does not appear my working in FME Data Inspector.
