Control feature append order
  • Oct 17, 2017 12:37 PM UTC
  • 5 replies
  • 111 views
I have a workspace with two creators which I use to create a single constant text line each. The rest of the workflow reads data and creates text lines depending on the content of the data (10 lines in this example). Now I want to write the text line of the first creator first to a text file, then the lines generated dependent on the data and the text line from creator_2 last. As Creator_2 is much faster then reading all the data in between, in the resulting text file I get the text line from Creator_1 first, then the line from Creator_2 and the lines from the data last. Is there a way to control that the line created by Creator_2 is written last?
So far I can only see that the Creator order can be controlled...
thanks,
Ludwig
Best answer by dustin
On the feature coming out of the first Creator, use your AttributeManager_1 to create an attribute of 'sort_att' with a value of 1. Use a Counter on the content data, with Count Output Attribute set to 'sort_att', and Count Start set to 2. On the last feature, use your AttributeManager_6 to create an attribute of 'sort_att' with a value of 9999 (just a number bigger than the number of content data features). Then feed all features into a Sorter prior to output, sorting Numerically and Ascending based on the attribute 'sort_att'.
thomas_merkus
Maybe you can combine a FeatureHolder, and a Sorter to make sure the features arrive in the right order to the Writer.
danilo_fme
Forum|alt.badge.img+58
  • Oct 17, 2017 12:50 PM UTC
Great suggestion @thomas_merkus
dustin
Forum|alt.badge.img+36
  • Oct 17, 2017 12:59 PM UTC
If there is no blocking transformer on the data flow from the reader (10 text lines), you can just set "Yes" to the Create At End parameter in the Creator_2.
  • Oct 17, 2017 1:15 PM UTC
@cartoscro: That's it. Very useful easy transformers. I am a FME noob, but start to love it more and more!
