Connect all From points to all To points in FromToBuilder
  • Mar 4, 2014 12:59 PM UTC
  • 157 views
daniel_l
Hi all,
I want to use the custom transformer FromToBuilder to connect all From points to all To points. I thought that by setting a common attribute for joining features where the value is set to 1 for all features would produce this M:M result. However, I've only managed to get lines from all From features to ONE To feature, in other words M:1.
Any ideas how to achive M:M?
gio
Forum|alt.badge.img+15
  • Mar 4, 2014 1:24 PM UTC
Hi Daniel,
Thats a full cartesian product FROMxTO.
U can achieve this by first, indeed merging using a common attribute.
First extract coordinates of points and name them apporpriatly.
Use a featuremerger, set proces duplicates and enter a listname.
On the output insert an listexploder and explode the duplicatelist. Now u will have the cartesian product.
If u have passed the x,y coordinates. U can now use 2DReplacer on the FROM points and a 2DPointadder on the TO points.
Thats all.
(i made a workbecnh while typing this, so if u want it, just holler :))
Have funs,
Gio
daniel_l
  • Mar 4, 2014 3:59 PM UTC
Hi Gio,
Thanks for sharing your solution idea, it seems to work fine for me!
Regards,
Daniel
  • Mar 5, 2014 2:35 AM UTC
Hi Daniel,
I had a look at definition of the FromToBuilder. You can customize it easily for your requirement.
1) Open editing window for the FromToBuilder (right-click on the transformer interface and select Edit on the context menu).
2) In the parameters dialog of the FeatureMerger, enter a list attribute name (e.g. "_list") to "List Name". And make sure that "Process Duplicate Suppliers" is "Yes".
3) Insert a ListExploder after the FeatureMerger. Specify the list attribute to "List Attribute" parameter.
After customizing, the workflow becomes almost same as Gio's suggestion.
Takashi
