combine values from multiple records based on number
  • Jun 10, 2020 1:19 AM UTC
  • 5 replies
  • 64 views
curtisd54
Forum|alt.badge.img+5
I have used String Searcher to find data with the name BORDER
However,
I am struggling finding the right transformer which will combine the two records into 1 :
this is based on number.
ie - combine
40_BORDER_QB
40_QD_BORDER
then rename the record afterwards
to : ie - 40_QD_QB
this will also have to be done for 65_GF_CR and 67_GF_CR
then merging with Provider data.
  • Jun 10, 2020 1:28 AM UTC
Try using the Aggregator, setting an attribute storing the number to the Group By parameter.
curtisd54
  • Jun 10, 2020 4:19 AM UTC
thank you Takashi!
how do i store the number to the Group By? It only lets me add in my field name
curtisd54
  • Jun 10, 2020 4:42 AM UTC
@takashi let me know if you can explain more, see my post above. thanks!
  • Jun 10, 2020 4:56 AM UTC
thank you Takashi!
If every StationSeriesName always begins with its number (some consecutive digits), you can extract the number with a StringSearcher and store it into a new attribute (e.g. called "_number"), as in:
curtisd54
  • Jun 10, 2020 5:15 AM UTC
it is taking all the records though, I want only the 6 records which are then merged to 3 records
40_QD_QB , 65_GF_CR and 67_GF_CR
