Collada instance materials with external reference targets
  • Feb 13, 2018 3:06 PM UTC
  • 80 views
I have a special collada file is seems. FME is able to correctly read and view the model however when it comes to textures, it's falling over.
We have a .dae file that uses Instance_material to refer to a target file directory and also makes reference to an object in the same call.
e.g
<instance_material symbol="wall" target="../materials/wall.dae#wall" sid="wall">
    <bind_vertex_input semantic="uv0" input_semantic="TEXCOORD" input_set="0"/>
</instance_material>
I found only one reference to someone with a similar issue.
I used https://www.khronos.org/files/collada_spec_1_4.pdf for reference
and https://www.khronos.org/collada/wiki/Using_URIs_in_COLLADA .
In theory it should work, but perhaps this is not supported in the Collada reader?
Thanks.
daveatsafe
Forum|alt.badge.img+24
  • Feb 15, 2018 7:56 PM UTC
Hi @pat8037,
Would you be able to share the Collada file with us? I would like to create an enhancement request for our development team. If you do not want to make the data public, please send a zip or download link to support@safe.com, attn. Dave.
  • Feb 16, 2018 5:43 AM UTC
Hi @pat8037,
Hi Dave, I've just sent off an email through the support email you provided. Details are in the email. Apprciate the help.
